vantodder
Message 1 of 4
Hafury mobile phone
My Hafury mobile phone will not work with BT sim card, what am I doing wrong.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Hafury mobile phone
Not much you could be doing wrong but:-
Have you installed the SIM card correctly - take it out, wipe the gold contacts with a clean cloth (a dry lens cloth works) and put it back in.
Does it work on bluetooth and/or Wi-Fi? if not it may be in airplane mode
StewM
Distinguished Guru
Message 3 of 4
Hi, I presume it is unlocked? Have you tried another SIM has it worked with another SIM? What error message do you get?
Stew
vantodder
Message 4 of 4
Thanks, now showing my pin is still in old phone, I dont have the phone or pin
