Message 1 of 4
How can I get a Nano Sim card?
Hey,
I've recently bought the Honor 8 from Amazon and it has a Nano Sim slot instead of a Micro Sim slot.
My current phone is the Motorola Moto G4 which only takes Micro Sim cards, of course meaning I need to somehow swap my Micro Sim for a Nano Sim.
Can someone please tell me how to do so?
Tags (5)
3 REPLIES 3
Guru
Guru
Message 2 of 4
Re: How can I get a Nano Sim card?
Just need to order a replacement SIM. I believe it will be a 3 in 1 SIM so just need to pop out the size you need.
http://bt.custhelp.com/app/answers/detail/a_id/53040/~/how-do-i-order-a-replacement-bt-mobile-sim%3F
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 3 of 4
Thanks. Will I keep the same number as I do now?
XRaySpeX
Recognised Expert
Message 4 of 4
Yes, that's what it is, a replacement for your existing SIM, specifically for when you swap phones.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
