Anonymous
Not applicable
Message 11 of 14
Re: How can I remove the temp bt number from my iphone so that people receive texts from my old numb
Obviously it should only respond to one or the other.
It sounds like the number port didn't work properly, I'd contact BT and ask for a SIM Update on the those grounds
Toonheid
Message 12 of 14
How do I do that?
Anonymous
Not applicable
Message 13 of 14
you can call them on 0800 800 150 or maybe one of the mods (e.g. @SeanD) could help
Toonheid
Message 14 of 14
Thanks Victor.
