I am getting calls on my mobile all from the same person but from Supposedly Tonga, Samoam Somalia, Papua New Guinea,Sudan she changes her number each time and I do block eah time but it is annoying. Anybody help,.
Hi @rogorton
It is hard when your number has hit some call list and you get random calls. Unfortunatly it is hard to manage these if they call from a bank of numbers and outside of the UK.
I would suggest you speak to the mobile chat team and see what they can suggest. It maybe a change of number maybe the only way to resolve this but see what they have to say
Thanks Dean. I,ve been onto BT but because they are coming thru on my mobile via Whats App they can do nothing about it apart from suggesting I change my phone number but with all the other changes I would have to make I do not want o do that. Had 3 calls in the last 10 mins last one from Somalia????.
Hi @rogorton
You failed to mention it was via what’s app. Why would you expect BT to resolve an issue with an app?
You are best contact the app developer or change your number.
Sorry I made a mistake the calls were not on Whats App. as I found out after I had deleted Ahat App from myMac.
As BT have said, change your number. On instant messaging apps - switch them to only those in your contacts
Thank you a much more sensible answer.
