CapnB0b
Message 1 of 6
How do I vary the data allowances for my family SIMs?
My kids need loads (pref unlimited), but my wife and I only need say 10 megs.  I can upgrade us all to 100mb each, but thats an extra £20+ per month
Any ideas welcome
5 REPLIES 5
Carlusha
Recognised Expert
Message 2 of 6
Re: How do I vary the data allowances for my family SIMs?
The family SIM comprises SHARED data. Say your package is 100mb, then that reduces as EACH of you use data.
CapnB0b
Message 3 of 6
Our billing isn't working like that
We have 4 SIMs on 'BT Mobile 25GB plan with Family SIM(s)' plan. If, say, I use 3gb and my daughter uses 30gb, we get charged for 5 gigs outside of the plan and the 22mb of mine not used is lost at the end of the billing period
CapnB0b
Message 4 of 6
apologies, I keep mixing my gigs with megs - its all gigs nowadays, right 🙂
-Richie-
Guru
Message 5 of 6
@Carlusha That is not how Family Sim plans work, each sim have their own allowance, nothing is shared.
@CapnB0b  what you could do is have 1 Family Sim plan with high data for the kids, then have different sim plans for you and your wife.
Carlusha
Recognised Expert
Message 6 of 6
@-Richie-
Thank you. I stand corrected. Apolgies to @CapnB0b
