trostre11
Newbie
Message 1 of 3
I can't make calls with my Samsung galaxy s7
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: I can't make calls with my Samsung galaxy s7
Any more info?
Has it ever worked?
Have you just moved across to BT mobile?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Moderator
Moderator
Message 3 of 3
Hi @trostre11 and welcome.
I'm sorry you're having problems with your mobile. If you can give us the information as requested by @Devon_Dave I'm sure we'll be able to help.
Cheers
David
