JMB
Expert
Message 1 of 4
I have ordered a replacement SIM card, present one is Micro SIM but need Nano SIM
I have replaced my mobile phone but did not realise that my present mobile phone has a MicroSIM and the new one uses a NanoSIM.
The MicroSIM does not seem to be convertible to NanoSIM like newer ones and I do not want to get brutal with it.  I presume newer issued ones can be used as MicroSIM or NanoSIM?
I have ordered a replacement and I was not asked which size so think they must all now be able to be used at any size.
MB
3 REPLIES 3
welshgit
Message 2 of 4
Re: I have ordered a replacement SIM card, present one is Micro SIM but need Nano SIM
hello, the sim card fits all ,it has 3 different sizes you just push out the size you want
StewM
Distinguished Guru
Message 3 of 4
Yes, they come as one and you break away the surrounding until you get the size you need.
Stew
JMB
Expert
Message 4 of 4
Thanks to both, I thought that was the case but just wanted to be sure.
My existing one must be a bit too old.
MB
MB
