Lotus888
Message 1 of 2
I want to upgrade my mobile now but my plan dosnt expire until november
can I upgrade my mobile phone even though my plan dosn't expire until november what is the procedure Thank You
1 REPLY 1
Dean007
Recognised Expert
Message 2 of 2
Re: I want to upgrade my mobile now but my plan dosnt expire until november
@Lotus888
Normally as long as the plan is upgrading to a higher plan, The best thing to do is log into your mobile account at bt.com and select the mobile number and it says change plan.. see if this allows the plan you want.
