on 02-07-2018 11h11
can I upgrade my mobile phone even though my plan dosn't expire until november what is the procedure Thank You
on 02-07-2018 12h51
@Lotus888
Normally as long as the plan is upgrading to a higher plan, The best thing to do is log into your mobile account at bt.com and select the mobile number and it says change plan.. see if this allows the plan you want.
