DNR19RE
Message 1 of 5
IPhone 6 voice messages don't show on the message screen with BT mobile. Why?
4 REPLIES 4
Dean007
Recognised Expert
Message 2 of 5
Re: IPhone 6 voice messages don't show on the message screen with BT mobile. Why?
Hi @DNR19RE
What exactly are you refering to? Visual Voicemail or voice messages sent via iMessage?
(Visual Voicemail is not currently supprted by BT Mobile)
DNR19RE
Message 3 of 5
Voice messages used to show as a list of contact names or phone numbers it now says Call Voicemail in the middle of the screen. I suspect its an IOS change.
Zombie
Expert
Message 4 of 5
Hello @DNR19RE it does sound like your are referring to “visual voicemail” unfortunately at the moment BT mobile does not yet support visual voicemail on iOS devices. You have to call up voicemail to listen to messages, hopefully it will be supported in the future.
clever_trevor
Message 5 of 5
Hi - I noticed on Vodafone & Three (as only ones checked) - a red dot appears on the phone icon when a voice message is waiting - Dont see this with BT Mobile - is this something can be set?
