Chrissymag
Message 1 of 3
Incoming calls barred
Hi I blocked all incoming calls on my Huawei p30 lite last night and have tried to disable it this morning but keeps saying operation failed, tried my sim in another phone and still blocked, any ideas please. Thank you.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Incoming calls barred
@Chrissymag
You could try contacting BT Mobile to see if they can cancel the redirect on your number.
First try dialling #21# to see if that helps.
I assume you have already tried the normal way?
To turn off or cancel call forwarding that you have set up, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap Call Settings.
  4. Tap Call Forwarding.
  5. Tap Always Forward.
  6. Tap Disable.
Chrissymag
Message 3 of 3
Yes tried the usual way, looks like I'll have to contact bt to solve it, thanks for reply.
