scottish_scrooge
Message 1 of 4
Iphone 5
Hi, will my iPhone 5 get a 4G signal on BT Mobile? It doesn't on vodafone or O2 but does on EE?
3 REPLIES 3
Message 2 of 4
Re: Iphone 5
enter your post code and check http://www.productsandservices.bt.com/products/4g-coverage-checker/
scottish_scrooge
Message 3 of 4
Re: Iphone 5
Hi, it's less about coverage and more about the 4g frequency of the iphone 5 being limited
hippey
Expert
Message 4 of 4
Re: Iphone 5
Yes, you will get a 4G signal a is you would with EE; BT is acting as an MVNO at the moment.
