andy350z
Newbie
Message 1 of 2
Is RSAP (Remote SIM Access Protocol) classed as tethering?
Hi,
I'm considering moving to BT Mobile. However my car uses Audi Connect which uses RSAP to take over the SIM from the phone via bluetooth to provide internet access to the SatNav for Google Map access etc.
I'm concerned that this will be classed as tethering and will be blocked.
Andy
Tags (2)
1 REPLY 1
Mancunian01
Message 2 of 2
Re: Is RSAP (Remote SIM Access Protocol) classed as tethering?
Currently the above set up will work fine.
That's not to say that BT won't change how they deal with tethering at some point, which may affect this.
Right now though, you're good to go.
