Dean007
Recognised Expert
Message 11 of 12
Re: Keep my number port gone wrong!
@Ryan1709
The moderation team are fairly busy at the moment but will deal with your issue as soon as it gets to the top of the list, if they havent already.
The process of of adding a number to a sim sounds easy enough, but it will take a little work. They will have to recover your lost number, apply it to the system so it can be added to a sim and then do a number swap.
The mods will be able to check up on the status and help just as soon as they can.
Moderator
Moderator
Message 12 of 12
Hi @Ryan1709 I called earlier on the contact number provided; sorry I missed you.
I've checked and can see that the BT Mobile offline team are working to fix the issues and have placed a port order which should complete tomorrow. Once that is completed they will then fix the plans. They should be in touch with you tomorrow to update your on these issues. Please keep the thread updated and I'm sure they will resolve these issues for you very soon.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
