Greenlands55
Message 1 of 3
Large Mobile data usage although at home connected to wifi
Hi
Ive just noticed that in the past 3 days whilst ive been at home all the time ive somehow managed to use 3gb of data, not sure how that is possible if connected to wifi.
I do listen to spotify whilst at home quite a lot however ive checked and the setting in there is correct in that it does not go via cellular.
I do connect to social media but i thought that would of all gone through my wifi.
this is baffling me, it used up all my monthly allowance in 10 days last month, its becoming un-managable.
Any ideas?
thanks
Clare
Tags (3)
2 REPLIES 2
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Large Mobile data usage although at home connected to wifi
Why not turn off mobile data until you need the internet when out of range of wifi?
Greenlands55
Message 3 of 3
ive found that spotify still uses 4g connection whilst your on wifi so i guess that your suggestion is the only way to avoid that, you have to be really careful with these apps, thanks
