vlk
Message 21 of 24
Re: MB refuses to connect to my home WI-Fi
It was unlocked by vodaphone when I bought it, and historically I was able to connect to my wifi, and can connect at my son's house, who also has BT. The android version is 6.0.1. Something changed a week or two after Christmas, and it wasn't anything I did. I think that I have exhausted every configuration setting and reset, and will have to go back to BT.
Distinguished Expert
Message 22 of 24
I've asked for Mod help for you on this problem.
Moderator
Moderator
Message 23 of 24
Hi @vlk and thanks for posting.
This could be a problem with the actual handset so I'm not sure if there's anything we can do to help but I'll be happy to take a look for you. Can you please drop over an email with your details? You'll get the contact link in my profile.
Cheers
David
vlk
Message 24 of 24
Following the intervation of a moderator, BT sent me a new hub and my phone was immediately able to connect to my wifi account again. Problem solved. I have no idea why the previous hub had ceased to 'authenticate' my phone when I could connect to other BT and non-BT wifi accounts.
