Polyanna
Message 1 of 3
MMS charge I did not add pic!!
Three times now when I've sent a text after I click send an advertising pic has been added on the bottom...then BT has charges me 40p for MMS...how do I prevent this on my Android Pixel phone??!!
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: MMS charge I did not add pic!!
Hi @Polyanna welcome to the forum and thanks for posting. If you are sure it is this pic that is causing the issue some phones let you switch the MMS function off, or enable you to set up an alert when it happens. You'll need to check the manual or go to the support website for your phone to see to do.
Cheers
John
Polyanna
Message 3 of 3
Hi JohnC2..Thanks. I had another one today added..German.so I'll do as you suggest
