pdug175
Message 1 of 4
MMS settings
I'm having trouble sending or receiving MMS since moving over to BT Mobile.
My APN settings where pushed to my phone from BT so I can't quite understand what is wrong.
I'm using a n LG G3 mobile. Running Android 5.0. See screenshots below. Is there something set incorrectly in the settings?
Thanks.
3 REPLIES 3
Message 2 of 4
Re: MMS settings
Settings look ok but you need to remember mms are not included in your package and are chargeable so you may well need money in your phone account
pdug175
Message 3 of 4
Re: MMS settings
Hey, thanks for the reply.
I am on a sim only deal so I was under the impression any mms usuage was simply added to my bill? MMS isn't restricted until you've paid a bill or two or anything like that is it?
Message 4 of 4
Re: MMS settings
Here are t&c https://www.productsandservices.bt.com/consumer/terms/mobile-service.html
would have ace thought cost would be added you your bill
there is a post just below yours with same problem
