mcfc4heatons
Message 1 of 5
Maritime Data Packages While Cruising Out AT Sea ??
Do BT Mobile have a maritime package for using data while out at sea? I have a lot of data incldued so when the ship dock, as we'll be Europe (Italy, Croatia, Monetenegro etc) I'll be fine using my included allowance, but I know it works differently once your at sea and maritime data isn't including ion your data allowance as I understand it?
Advice please 🙂
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Maritime Data Packages While Cruising Out AT Sea ??
Hi @mcfc4heatons welcome to the community and thanks for posting, no sorry there are no data roaming plans offered for use when on a cruise.  If the ship has a wifi service it may be worth looking into as it would be much cheaper than using data on your mobile.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
mcfc4heatons
Message 3 of 5
Thanks, and presumably you can buy bolt on data packages for countries not in the EU? We stop at Montenegro for the day and I notcied Montenegro is NOT on the EU, so glad I checked now 🙂
Moderator
Moderator
Message 4 of 5
@mcfc4heatons no problem,  there is a BT Mobile Data pass add on for some countries outside of the EU but unfortunately Montenegro doesn't appear to be included.
Kudos”Kudos”
Iangla
Message 5 of 5
If you couldn't abide with tourist wifi in Montenegro you will be able to get a cheap SIM when you arrive.  its often cheaper than  buying roaming for your current package. have a google and see if any of the local operators do a tourist sim, I'd expect there will be a good market for them if they are outside the EU roaming area.
