indrapun
Message 11 of 26
Re: Merge two accounts
Yes! Sorry for earlier. I am indeed available
Dean007
Recognised Expert
Message 12 of 26
Hi @indrapun
Just a little tip, when you reply to a post include the persons name so it flashes up on their list as they dont alway see every post. So in this case @JohnC2 Smiley Wink
Moderator
Moderator
Message 13 of 26
Hi @indrapun Thanks for taking my call. I've dropped you a Private Message (PM) to explain what I need to get done to get your accounts merged. Please can you check this message and let me know if you are OK for me to make these changes.
Cheers
John
Moderator
Moderator
Message 14 of 26
Hi @indrapun the account merge is now complete. I have sent you a PM with a more detailed explanation of the changes to your account.
Cheers
John
indrapun
Message 15 of 26
Hi @JohnC2,
I have PMed you with the mobile app screenshot of the homepage.
Regards
Moderator
Moderator
Message 16 of 26
Hi @indrapun,
@JohnC2 is not in the office today. He is back in tomorrow and will follow up with you then.
PaddyB
indrapun
Message 17 of 26
Thanks a lot @PaddyB
indrapun
Message 18 of 26
I am still waiting for this issue to be resolved. Any idea whats going on?
On the other hand when I go to My BT, it is now showing that I have exceeded the data allowance even though that mobile has double data enabled.
Moderator
Moderator
Message 19 of 26
Hi @indrapun Sorry that this is taking much longer than I had hoped to be resolved. I'm working with our BT Plus colleagues to try and this these issues fixed for you asap.
Cheers
John
indrapun
Message 20 of 26
Hi @JohnC2,
I was hoping it would be resolved by now as well. As for the 2 account still not showing up in My BT, I had sent you the screenshot. I hope they are looking into it too.
Regards
