shaunkea
Message 1 of 5
Minecraft on BT 4G Home Hub
How do you get Minecraft working on a BT 4G Home hub for PC version I can get it working on ADSL broadband no problem. The Teredo Server connectivity is blocked but Support says no restrictions but it works on the ADSL no problem
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Minecraft on BT 4G Home Hub
@shaunkea
Mobile networks use CGNAT, which means that you do not get your own IPv4 address, but an IP address which is shared among a number of other users.
https://en.wikipedia.org/wiki/Carrier-grade_NAT
That means that any application which needs port forwarding, will not work.
shaunkea
Message 3 of 5
Thank you for the Info Keith now I know how it works we used a VPN and Minecraft works with Multiplayer now
sarahpopple
Message 4 of 5
Hi
We have 4h home hub and my son can't play multiplayer Minecraft..we are in admin area, but can't see how to change NAT type from strict?  Does anyone have answers on how to get it to work?
sarahpopple
Message 5 of 5
Hi
can you explain please how you got it to work? thanks
