Message 1 of 3
Mobile Data not working.
I received my BT sim through the post a few days ago, and started using it straight away, everything working fine (mobile data, calls, texts). I then decided to transfer my old number to my BT contract, to avoid having to contact people with a new number. This all worked fine, however my phone will not connect to mobile data, and shows no 4G, H+, 3G or other notifications when I turn on mobile data. I've tried everything I can think of (APN, switching to the correct service providers, and even tried a factory reset- lost all data and had to start again) and it still doesn't seem to be working. All I can think of is that because I've used the mobile data on the old number there's been a problem activating it on the new number. Any help would be appreciated.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Mobile Data not working.
Hi @joejwanderson,
Welcome to the community forum and thank you for posting.
I sorry to hear that your mobile data isn't working. The best thing do do is to contact the Mobile Chat Team
Give that a go and let me know how you get on.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 3 of 3
Further to the above [good] advice, is there another mobile you can try your sim card in?
 Also does another sim card in your phone allow your mobile to use data?
Edit:   If you ionstall the android app 'Network Signal Information' by Kaibits on your phone, you will be able to detect whether there is actually a data signal [and what type of data] is in your vicinity. [If you are an i phone user, I'm sure there will be a similar app at your disposal].
AQ.
"Welcome to Royston Vasey - You'll never leave."
