Message 1 of 4
Mobile Phone Deals
Hello everyone
After some advise. At present my wife and i are on Sky mobile sim deals but looking to change phones upgrade as signal is not great in the area.
Do BT do a deal where they provide 2 phone/sim deal?  would be good to get it all under one option.
Not 100% sure whats happening now with EE and BT is it worth just going straight to EE shop and discussing there?
Sorry any help would be appreciated.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Mobile Phone Deals
BT no longer offer mobile, so you'd need to look at EE. If you go to your MyBT page you should see this:
But don't just assume it's a good deal, make sure you compare fully elsewhere, including direct with EE where there may be significant cashback on offer via TopCashback or Quidco.
Message 3 of 4
Thanks so much with the quick and very helpful reply. not changed my phone for years so do appreciate the guidance
Message 4 of 4
If you have BT broadband, login to www.bt.com/mybt and look at mobile options there, it will then direct you to the EE website with a 10% discount applied as a BT broadband customer, if your BT broadband is a Halo package then you also get double data on the EE mobile.
Another helpful feature that EE do data gifting, so you can share the data between plans if one needs a bit more, I have unlimited data and share 100GB between the other 3 numbers on my account, super useful for keeping costs low.
