Meekablue1
Message 1 of 2
Mobile change over
Changing providers - recently got new mobile from BT a Huawei from a Samsung through BT does anyone know if one can get the mobile numbers changed over without having to put them all in manually? BT are keeping my old number but the other is such a nightmare - there must be a way! Thank you Jane
1 REPLY 1
DanielS
Moderator
Moderator
Message 2 of 2
Re: Mobile change over
Hi @Meekablue1,
There are a few different ways that you can do this. If your Huawei uses Android then saving the contacts to your gmail account, and then using that gmail account on your Samsung, is usually a quick way of moving them across. Samsung have a self help article for importing using bluetooth: How do I transfer contacts using Bluetooth?
DanielS
