Message 1 of 4
Mobile data abroad
Had my sim pre-Brexit so up until recently, I have used my data abroad.
Currently and on my last trip abroad, my phone just doesn't get data. No text to say I'm in a new country, no signal, nothing.
I have tried to manually set it up and got BT to reset my sim at their end but it hasn't workes. Any advice?
3 REPLIES 3
Message 2 of 4
Re: Mobile data abroad
has phone got data roaming turned on?
are you set up in MYBT for international calls and also set the spend limit to greater the £0 say £5?
Message 3 of 4
Data roaming is on. I've previously never had to do the latter, why would I need to it auddenly and how do I do that?
Thank you
Message 4 of 4
you need to go to MYBT and mobile and ensure settings are correct
