Mrsmartin2016
Message 1 of 5
Mobile handset
I took out a Samsung s20 mobile on contract in December 2020
it was straight in a case with protector on and has never been dropped
Ive noticed the sound is crackling and not very clear and also seems to repeat when on video.
What do I do in regards to the device as it’s only 5mnths old.
4 REPLIES 4
-Richie-
Guru
Message 2 of 5
Re: Mobile handset
The BT help pages have the following :
Yes, every BT Mobile handset has a warranty provided by the manufacturer. Check with them for more details.
Apple support
Sony support
Samsung support
Google support
Nokia support
Nexus support
If your handset breaks down, give us a call on 0800 800 150. We'll try to fix the problem as quickly as we can, ideally without you having to send the handset in for repair. If it does need to be repaired, we'll sort everything out for you.
pottyperson
Distinguished Guru
Distinguished Guru
Message 3 of 5
Re: Mobile handset
Although they are responsible for dealing with faulty goods for 6 months, retailers routinely try to fob customers off with the manufacturer's warranty. Which? give full advice here, the relevant paragraph being this:
If you don't reject the goods within the first 30 days, and find a fault within the first six months of possessing your faulty goods, you'll need to give the retailer a chance to make a repair or replacement. If that's unsuccessful, you can then ask for a refund.
Mrsmartin2016
Message 4 of 5
Re: Mobile handset
Thanks for the reply
am I better contacting Samsung support then as it’s not a complete breakdown of the phone
pottyperson
Distinguished Guru
Distinguished Guru
Message 5 of 5
Re: Mobile handset
I would tell BT that you want them to replace or repair it. I'm not an expert on consumer law but Which? are, and they advise in the link I posted that the onus is on you to prove an existing fault after 6 months, implying that before then the onus is on the retailer to prove that it's acquired damage.
