Ramondo75
Newbie
Message 1 of 3
Mobile plan
When does the recontracting window start before your current plan finishes
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Mobile plan
Erroneous post. Deleted by poster.
JeffTG
Message 3 of 3
Re: Mobile plan
Hi Ramondo75
You can Upgrade (re-contract) your handset to another handset from 3 months before the end of your contract or you can upgrade your handset to a SIM Only product if you are within the last month of your contract.
If you Login to BT.com MYBT/MyMobile you should see a yellow banner when you become eligble to Upgrade.
