My bt mobile signal at home is poor, I am waiting to upgrade to fttp broadband soon, i
have got a bt contract with bt broadband and mobile at the moment,
so will fttp be a new contract if yes can I cancel my mobile with bt.
Your BT Mobile is a separate contract, so you could not cancel the mobile if you are still in contract with your mobile, without incurring cancellation charges.
Your FTTP will still be a bt broadband contract just a new fixed term. It will not change your mobile contract which you need to honour
So will bt supply a assist box for my mobile. When I had trouble with my landline
last year I had to drive 2 miles To where the mobile mast is located so i
could use my mobile.
@helzapoppinwrote:My bt mobile signal at home is poor, I
Surely that is nothing to do with your FTTC or planned FTTP broadband connections? You are referring to your MOBILE SIGNAL strength and not your mobile phone's ability to connect to your wifi at home?
The latter should be fine but for a mobile signal it depends upon where the nearest mast is located and, to some extent, the actual mobile phone itself and whether set to 3g and 4g if available.
I know my mobile signal got nothing
To do wtih my broadband, i was just
Saying what had to do to get a moblie
Signal so i could talk to a bt customer service agent to get my landline
Fixed !.
