Message 1 of 4
Mobile text charges
Hi all, I've just joined BT, and been sending my new mobile number to my contacts. But just received a text saying I'm nearing my £40 overspend!!!! Please help as I cannot afford the extra charges, I thought I had unlimited texts. Please advise
3 REPLIES 3
Guru
Message 2 of 4
Re: Mobile text charges
Hi, have you looked in your MYBT account to see what the charges are? Perhaps you are sending picture messaging instead of text messages?
Stew
Expert
Message 3 of 4
All BT mobile plans include unlimited text messages, these are sms, if you send large messages or includes images they become mms, which are not included.
Check with the billing team to see what the charges are, you can also set yourself a spend cap, any where from £0.00, £2.50, £5.00 and upwards, this will prevent this happening in the future.
Lastly have a look at I'm being charged for texts when I thought they were included in my plan :
Sometimes you might get charged for a text message even though most texts are included free in your plan or you have plenty of allowance left. This is often because your phone has converted your text (SMS) to a picture message (MMS). Picture messages aren't included in your plan.
Typically, phones will convert text messages into picture messages when:
  • you send a group text message
  • your text has a non-standard smiley or symbol (such as an emoticon or emoji)
  • your text goes over the character limit (on some phones this is 160 characters, but on others it's more)
  • you add text to the subject field
On some phones you can clearly see when this happens - for example, you might see a character count changing to a file size.
Some phones let you switch this function off, or enable you to set up an alert when it happens. You'll need to check the manual or go to the support website for your phone to see to do.
Message 4 of 4
thanks for the reply, i spoke to customer services and got this sorted
