Message 1 of 4
Mobile use in the carbean
we are both on Bt mobile with roam like home but as we are going to the Caribbean this won’t be much use.  I have looked on the Bt site but can’t find much information about bolt ons for this part of the world
3 REPLIES 3
Message 2 of 4
Re: Mobile use in the carbean
Hi @Cselvidge1956,
There are no add-on's covering the Caribbean unfortunately. You can find the costs of using your phone whilst there by going to our tariff guide here BT_PhoneTariff_Residential.pdf and then select BT Mobile then Roaming Charges. It will show which zone each country belongs to and how much using your phone in that zone will cost.
Alex
Message 3 of 4
Thanks that explains why I couldn’t find anything 🙂
Message 4 of 4
What I do….
- Turn off mobile data completely. However leave Airplane mode off so you can receive calls and texts, but don’t make any yourself away from WiFi locations unless it’s an emergency.
- Use Wi-Fi only for apps and internet surfing - most resorts have good coverage. Then use Skype to make calls / texts home over Wi-Fi (either to other Skype users, or add some credit to make normal phone calls).
