kevocl
Message 21 of 24
Re: Monthly Spend Cap - Add an option for £0
I'd argue that the £5 isn't fine, it's the lowest option available. If I had the choice of lower options, I'd choose them.
SeanD
Community Manager
Community Manager
Message 22 of 24
Hi Everyone,
I have some great news.  Some of you may have already noticed but BT has changed the threshold for setting a mobile spend cap on BT Mobile accounts.
From yesterday (Sunday 1st July) BT mobile customers can now set a spend cap of £0 or £2.50.  Prior to this change the minimum level was set at £5.  This will help avoid any unexpectedly high bills Smiley Happy
You can read some more information on managing your mobile spend from this link,
How can I manage my BT Mobile spend?
Cheers
Sean
joebhoy
Message 23 of 24
Excellent. Good to know they are listening.
clever_trevor
Message 24 of 24
Oh WOW - that is """brillient""" - HUGE THANK YOU - I know its a perhaps a small thing to many - but now I can relax knowing that once I hit my limit all stops until the next billing cycle - rather than keep checking usage.
I will now definaley be staying with BT mobile  🙂
