Clare2
Message 1 of 5
Moto G5 incoming calls going directly to voicemail.
Anyone any ideas why my Moto G5 should be diverting all my incoming calls automatically to voicemail without any audible ringtone? Very frustrating!
4 REPLIES 4
Clare2
Message 2 of 5
Anyone any ideas why my Moto G5 is sending all incoming calls directly to voicemail and bypassing the ringtone?
Distinguished Guru
Distinguished Guru
Message 3 of 5
Re: Moto G5 incoming calls going directly to voicemail.
If it's standard Android go to Settings > Call > Call forwarding > make sure Always Forward is disabled.
V_Meldrew
Recognised Expert
Message 4 of 5
This changed with Android 7 or 8 (can't remember which).
Open Phone Dialler (instead of settings) and tap the menu icon (the three dots) in the right hand corner).
Then tap Settings, Calls & Call forwarding
Message 5 of 5
