Dean007
Recognised Expert
Message 41 of 65
Re: Move to BT Mobile. Poor signal!
Hi Jayteepix
There are many discussions about the booster box, Bt Mobile have had two trials of these. Whislt BT own EE they are run as two seperate companies, BT Mobile only uses the network under a MVNO service agreement.
BT are currently testing 4G calling & wi-fi calling, this to me having tried a signal booster box is a much better solution. The booster box has to be connected to your home hub, and allows upto 4 users to use a 3g signal with a limited radious. 4G/Wifi calling allows you to connect to any wifi network in the UK that allows that type of protocol even when away from home.
BT Mobile are clearly working towards this, as it recently started to show text on their website and app but no date for the launch has been confirmed.
If you are unable to wait for wifi calling then maybe it is best that you try another mobile network. I would suggest getting friends on various networks to visit your home at different times of day and see which gives the best coverage.
jayteepix
Message 42 of 65
4G watsat- rural Somerset get 2G like it or lump it 🙃
Dean007
Recognised Expert
Message 43 of 65
Then maybe people need to move house as well as mobile networks ;-D
jayteepix
Message 44 of 65
So true <LOL>
grandange
Newbie
Message 45 of 65
It is the same here! and has gone from poor to non existent. I have to walk 400 yds to get a signal! Does BT take notice of these forums?
Igraine
Newbie
Message 46 of 65
I've also just moved (mobile number transferred yesterday) because the Tesco Mobile signal was getting worse and worse.   Did all the usual coverage checking:  2, 3 and 4G all excellent.   Nope.   The signal is almost as bad as Tesco's!     The person on Live Chat checked coverage.   The same result.   Even in town I'm lucky if I have two bars.   Luckily I am in the cooling-off period and, even with the hassle of changing providers yet again, I'm thinking of cancelling.   The package offered by BT was certainly good (apart from the £50 voucher to spend on ridiculously expensive phones!) but the very poor signal isn't worth the aggro.
davepearce37a1
Message 47 of 65
Hi have you tried turning mobile data off in settings and use your Wi-Fi in doors. Making sure that it is also set to 3G and not 4G.
Hopefully within the next couple of weeks Wi-fi & 4G calling will be up and running.
Igraine
Newbie
Message 48 of 65
Hi davepearce37a1
I've done that - I'm now wondering if it's my somewhat ancient phone - Samsung Galaxy S3 Mini GT-i8190N, although that wouldn't explain the poor coverage for 3G.     Even in town (Yeovil) the signal is dropping out:  Tesco Mobile was good there.     So frustrating and annoying!
Dean007
Recognised Expert
Message 49 of 65
@Igraine
If you can get someone with a BT sim or and EE phone and see what their reception is like..
Also as you may have seen, BT have started to migrate sims over for 4G and wi-fi calling, the wi-fi calling will help with indoor coverage, and the extra band that comes with 4G calling (VoLTE) should improve outdoor coverage too.
You never know, BT may even do some offers on handsets for the launch of wifi calling..
Max2
Message 50 of 65
I have had exactly the same problem, in fact the longer I get in to this 12month contract the worse the coverage is getting.
