tiredhero
Message 1 of 7
Moved to BT and no access to parental settings
So i got 2 sim cards one number stayed the same.. no problem with that sim...  then typically mine, i wanted a new number so got a new number and now i can not access the parental controls. It says im still being swapped over to bt.. i was wondering how long does this  take and also why am i unable to change parental settings? Any help would be greatly appreciated
6 REPLIES 6
NeilO
Moderator
Moderator
Message 2 of 7
Re: Moved to BT and no access to parental settings
Hi @tiredhero, welcome to the community and thanks for posting, it normally takes around 24 hours from when the order is placed for it to be completed, is it still showing as open in MyBT? Once the order is closed you should be able to manage the parental controls.
tiredhero
Message 3 of 7
Hi and thanks.. yes i have had this for around a week now.. its still the same so i guess i have something wrong with my sim or the change over.. surprise surprise virgin media causing trouble for me still.. (wouldn't surprise me if they have messed something up so i can not switch propperly)
tiredhero
Message 4 of 7
 still like this
Matt-S
Moderator-Retired
Message 5 of 7
Hi @tiredhero,
Can you double-check that your BTID is set as the account holder?
  1. Log in to My BT >
  2. Click on Settings and Your account
  3. Scroll down and you'll see if you're an Account holder or Account manager
  4. Click on the I should be the Account holder link and follow the steps
If the BTID does have account holder status and you are still getting the same error please reply to my private message that I have just sent you.
Matt
tiredhero
Message 6 of 7
so i have done all of the above i have also phoned as i waited a few days.. i can not get on to the mobile page of my bt products no longer either for some reason(kicks me back to the main page)..
tiredhero
Message 7 of 7
i have now filed a complaint
