Message 1 of 2
Moving Contacts
My husband is moving from Vodafone to my BT account and also moving from a Nokia non-smartphone to a Doro smartphone. He is keeping is old phone number. I have been told that he cannot use his old SIM card which holds his contacts. How can I transfer his contacts to his new smartphone or must they all be re-keyed?
Thanks for any help.
1 REPLY 1
Message 2 of 2
Re: Moving Contacts
Hi @ProjectGal welcome to the community and thanks for posting.
The contacts will likely need to be saved to the Nokia from the sim first then use the Bluetooth facility to transfer them over to the new phone. If you look up the user guide for his Nokia it should explain how to do this if the facility is available.
Neil
