Message 1 of 2
My mobile data doesn't work on instagram
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: My mobile data doesn't work on instagram
Hi @Ollyshrewsbury  welcome to the forum and sorry you cannot use your mobile data on Instagram. I've checked and there was a Similar Issue for a user before and Parental Controls caused the issue.
If that doesn't help you would be best to contact the BT Mobile Faults chat team and they will be able to help you further.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
