pokchop
Message 1 of 8
New BT Mobile Sim
I have received a new sim card with a different number to my old one. (after upgrading)I went through the BT chat with someone  and she said it was now sorted. I have checked on my mobile app and it appears I have 2 sims on my account can you please check if this is correct. I have tried to get back through BT Chat but to no avail. So I am now trying to get help from here.
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: New BT Mobile Sim
Hi @pokchop,
We can check this for you. To reach us, click on my user name and then on contact the mods. It may take us a few working days to get back to you but we will do our best to help you.
DanielS
pokchop
Message 3 of 8
Thanks Daniel,I did eventually get through to BT Chat and hopefully it has now been sorted.
annerayment
Newbie
Message 4 of 8
Same problem for me - why does BT make something so simple, so complicated.
pokchop
Message 5 of 8
I cancelled in the end, couldn't be bothered anymore.
vernon80
Message 6 of 8
BT mobile is fine when its working, but the simplest problem they turn into a long drawn out disaster that gets worse the longer it goes on, as I am discovering for the last 2 weeks
vernon80
Message 7 of 8
You would think that an organizasion like BT could at least ensure I could activate the sim they have supplied for a brand new phone, they have told me to activate, but when I try,  the site says you have no sims to activate, and to rub it in they have  sent two emails this afternoon reminding me I have not activated my recent sim. Numerous phone calls are met with yes there is an error that we are working on it.
vernon80
Message 8 of 8
Well surprise. surprise, we have now got a working Mobile, after over 2 weeks agro, having said that it worked for a day 10 days ago so I wait in hope it continues.
