Message 1 of 3
No Data After Re-Contract
Hi All
Family SIM package with 4 SIMS started new contract on Sunday. One of them is unable to use data, checked all settings, looks OK. Could be a co-incidence but unlikely. Only thing I noticed was that on the confirmation email this SIM had no out of plan allowance, but I have changed that just in case.
Looking for advice on any settings or diagnostics, also best way to contact someone who can help. Thanks.
Graham
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: No Data After Re-Contract
Hi Graham,
You're best contacting customer service by dialling 150 from your mobile and speaking with the team about this. If you have bundled data you shouldn't need to increase your spend limit for it to work
Message 3 of 3
Hi garetc
I have spoken to BT mobile, they were very helpful and checked SIM was registered correctly and local mast was OK. Unfortunately the phone is not "on site" for me to play with so I'm having to do things remotely. I was hoping someone would come up with a "I've had that, I just pressed X button to get it to work" ;-)#
Appreciate the reply.
Regards
Graham
