AdeBow
Message 1 of 3
No Mobile data connection
About three weeks ago i changed over from EE to BT sim only 6gb package, my number was port forwarded, so far i have only had one day on my data connection, i rang last week and the help guy said their having problems with EE, all my mobile settings are correct.I live in Crewe and work in Nantwich, i dont get a connection anywhere. TIA
2 REPLIES 2
AdeBow
Message 2 of 3
Re: No Mobile data connection
Solved, data connected when I reset the BT app ☺
Moderator
Moderator
Message 3 of 3
Hi @AdeBow
Welcome to the forum and thanks for posting back again to let us know that you got everything solved.
I'll mark your second post as the solution also for the benefit of the community.
Cheers,
Robbie
