clairespencer
Message 1 of 5
No SIM Card
Hi all,
My phone is 100% unlocked as my husbands BT Sim works in my phone.
When I insert my new BT sim into my phone it says "No SIM Card" - it's not recognising it.
Any ideas?!
Tags (3)
4 REPLIES 4
Fusionmoth
Message 2 of 5
Re: No SIM Card
Could be static , touch the gold contact area with your skin to earth it and same for the SIM card reader ...no SIM messages suggest no electrical connection - I.e put a piece of foiling the phone and it would tell you that there's no network
Twoey2
Newbie
Message 3 of 5
Re: No SIM Card
It's a problem with the SIM. Get it replaced.
clairespencer
Message 4 of 5
Re: No SIM Card
All sorted now people Thankyou - the SIM was faulty and needed a replacement
spacepilot
Message 5 of 5
Re: No SIM Card
I had a 'no SIM' card message on my phone, which I thought was due to the SIM having not been activated.
an hour after the 3 hour activation dead line, i took the SIM out, turned it aound so that the 'clipped off' section was at the top and not at the bottom, and put it in again... it activated within a minute. i.e. i had put the bottom in the top.
I had thought it was a faulty sim,
________________________________________________
welcome to the world of last wednesday week.
there's now't wrong with 2 cans and a piece of string. at certain times, it is often faster.
