Message 1 of 9
No Voicemail Notifications
I'm not getting any notifications when I have voicemail.  No SMS, no spool icon.  I've restarted my phone, cleared the cache, checked all the settings.  I was on the phone for half-an-hour yesterday with a lovely guy called Robin from the BT helpdesk yesterday but he didn't manage to fix it.  Any ideas what's wrong and how I can fix it?  My phone is an S7 Edge with all the updates installed.
Thanks all.
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: No Voicemail Notifications
Hi @RagTailedFox,
If you contact the Mobile Chat Team, they'll be able to help you with this.
Give that team a try and let me know how you get on?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Message 3 of 9
Hi Paddy
Thanks for the reply. The link just goes to an error page, though. Do you have another link?
Fusionmoth
Message 4 of 9
Have you tried dialling 15710 (off) and then dialled 15711 (to turn back on)? When you do 15711 you should hear the robot woman tell you that your voicemail is now enabled - just throwing it out there that it may not be active to begin with, or the age old "turn it off and back on again" lol
Numbacix
Newbie
Message 5 of 9
I know this is now a year old so I hope you've got it sorted by now but in case you haven't, I have recently had the same problem with my s7. Just out of curiosity I checked my blocked numbers and lo and behold the voicemail number was there. I'm guessing it got moved during a software update. Unblocked and now getting notifications
Ronnie234567
Message 6 of 9
I am curious to know why if on EE you can have visual voicemail but on BT (which runs on the EE network and is now owned by BT), you cannot.
Dean007
Recognised Expert
Message 7 of 9
@Ronnie234567
Although they are both part of the same group, they operate as two separate businesses. BT, is hosted on the EE network and is an MVNO.
Imagine EE as  full milk, offers everything you need at more expensive price and BT mobile as Semi-skimmed  milk... it’s milk but just just doesn’t offer you everything full milk does, and that’s why it’s cheaper. It wouldnt be a good business practice to have two companies both offering the exact same with one almost half the price.
Interlaken
Newbie
Message 8 of 9
This is the answer!  Many thanks.  I have had this problem on every flippin Samsung Galaxy I have owned and now on S8+
To access blocked numbers press green phone icon the tap the 3 small dots top left, then settings and bloked numbers is in there and sure enough I have just done updates.
hogg
Message 9 of 9
I had exactly the same problem - and the same answer worked.
Voicemails left but no SMS notification to say there was one - and 1571 was, somehow, on my blocked numbers list.
Go to the dial screen, hit settings, hit blocked numbers and remove 1571 if it is listed there.
