Herbert1
Newbie
Message 1 of 3
No account info
When i log into my bt account.. im not seeing any information.. just says try again later.. ive been tryin to access my bt mobile information for 4 months now and still it says ... “try again later”. Any help please bt!
2 REPLIES 2
-Richie-
Expert
Message 2 of 3
Re: No account info
Contact the BT Billing team, they can check your BT ID is correct.
Moderator
Moderator
Message 3 of 3
Re: No account info
Hi @Herbert1,
I am sorry to hear you haven't been able to access it.
You can reach the billing team on 0800800150.
If you need any help from us, please let me know.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
