Expert
Message 1 of 4
No data coverage on one iPhone 6S while the other is fine
We have 3 BT Mobile Sims and 3 iPhone 6s mobiles.
My Wife and daughter are currently out shopping (surprise!), and literally standing next to each other, but only my daughter has a data connection (and a decent 4G one at that), whilst my Wife has no data at all but can make a call.
She has restarted her phone 3 times but to no avail.
Any ideas what else we can try to kickstart her 3G/4G?
3 REPLIES 3
Recognised Expert
Message 2 of 4
Re: No data coverage on one iPhone 6S while the other is fine
hi @stereohaven
You can try going into settings - Mobile data - Ensure mobile data is on - Mobile data Options - Enable 4G
You can also perform a soft reset
  1. Press and hold the Power/Sleep/Wake button and Home button together at the same time.
  2. Keep both buttons held down for 10 seconds.
  3. Do not release the Power/Sleep/Wake button and Home button until the home screen flashes and the Apple logo appears.
If none of the above work, have a chat with BT Mobile Online Chat
I know one of the phones has reception, but it may not be connected to the same cell site, check the local area on BT/EE Network Checker BT/EE Service Status
Expert
Message 3 of 4
Thanks for that, the soft reset seems to have done the trick.
Recognised Expert
Message 4 of 4
@stereohaven
Glad it worked! If you have any problems again pop back!!
