Message 1 of 5
No signal
My signal is so rubbish that I can't maker receive calls most of the time. Sometimes I get 2 bars but it doesn't last for long and I even have mostly no bars even when outside. I am unable to receive calls from my gp and therefore cannot get healthcare. I can't phone bt and their online chat service keeps saying there's nobody available to connect to. I literally can't do anything!
4 REPLIES 4
Message 2 of 5
Re: No signal
did you not check the BT/EE mobile coverage in your area before getting a BT mobile contract?  Is there better coverage by another mobile provider?  does your mobile no have wifi calling?
Message 3 of 5
Re: No signal
I got bt mobile because it came with broadband. I came from virgin media which I had to leave as they didn't have cables to my new flat. If I could have I would have stayed with them.
I'm unsure how to get or use WiFi calling.
The signal has been really poor all day and even outside in different areas of the city whereas others I know with ee have no problems in the same areas.
Message 4 of 5
Re: No signal
Not sure what you mean with "it came with the broadband".
BT mobile does not come with broadband you must haves selected it when you signed up as you could have used any provider of your choice.  You do get preferential rates but it was your choice.
If others get a good signal then I would look at your phone setup
Message 5 of 5
Re: No signal
It made sense to leave virgin mobile when I couldn't bring it to the new flat as the price would double and the bt mobile with the broadband if I got them the same time was just a tenna a month for way more than I needed. It was a no-brainer.
I'm not sure how my phone setup would be any different than it was before whilst on virgin media. How do I see if the setup is wrong?
