Lozzab234
Message 1 of 6
Not receiving texts
Hi,
When I ring my boyfriend on the number he rings me on he receives my calls but as soon as I text my boyfriend with the same number someone I don't know is receiving the texts
Can anyone explain how this is happening please.
5 REPLIES 5
Seamaster
Message 2 of 6
Re: Not receiving texts
Do you mean texts (SMS), or do you mean messages in an app like iMessage? If the latter, you need to check what number he has associated with the application.
Lozzab234
Message 3 of 6
He hasn't a Samsung but the texts are going to someone with iMessage, he only received his sim yesterday
Lozzab234
Message 4 of 6
He has*
Moderator
Moderator
Message 5 of 6
@Lozzab234 A temp fix would be to turn off iMessage on your phone and it will be sent as a text and he should get it. Then get your boyfriend to report the issue to the mobile helpdesk.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Fusionmoth
Message 6 of 6
Or just pop his number into this: https://selfsolve.apple.com/deregister-imessage
