pete_S
Message 1 of 31
Open order stopping SIM activation
I ordered an additional SIM last week, and it was delivered a couple of days later, last Friday.  However, the order status still shows as Open, so I can't activate the SIM.  The order was due to complete yesterday, but it's still sitting on Open.  I tried talking to chat, and they just told me that I can't activate it when it's Open, and there's nothing they can do about the status of the order.
Anyone got any ideas what to do?
30 REPLIES 30
Dean007
Recognised Expert
Message 2 of 31
Re: Open order stopping SIM activation
Hi @pete_S
Open orders are a pain, trust me I have experienced a few. You just need the right person to help and send it to the right team.
I will ask a mod to come and help, watch for them posting.
pete_S
Message 3 of 31
Thanks Dean
PaddyB
Moderator
Moderator
Message 4 of 31
Hi @pete_S,
I'll be able to help get that order closed off. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
pete_S
Message 5 of 31
Thanks Paddy - post on its way
pete_S
Message 6 of 31
Reference number is #180620-******
PaddyB
Moderator
Moderator
Message 7 of 31
Hi @pete_S,
Thank you for confirming. There are a few cases ahead of you in the queue and we'll reply as soon as we can.
PaddyB
JohnC2
Moderator
Moderator
Message 8 of 31
Hi @pete_S Thanks for sending over your details. I've checked and the order is stuck so I have had to raise a fault to get our systems team to get the order moved on towards completion.
Cheers
John
pete_S
Message 9 of 31
Thanks John.  As you say, it's still stuck at Open, so I'm keen to get this sorted asap so that I can activate the SIM.
Thanks for your help
Peter
Seamaster
Message 10 of 31
John, I’ve got exactly the same problem. I did get the mobile chat team to activate my SIM, but the order being stuck means I can’t make any other changes to my account. Can you help get it closed, please? Thanks.
