humanracer
Message 1 of 3
Phone siginal says "no service"
My phone goes between No Service though briefly it will show BT but not strong enough siginal to make any calls. My partner, who is with Three, also cannot make calls. The phone siginal is usually perfect in our village.
2 REPLIES 2
Technonerd
Message 2 of 3
Re: Phone siginal says "no service"
Sounds like there's a problem with the mast providing your area, as the problem is affecting more than one provider.
Dean007
Recognised Expert
Message 3 of 3
Hi @humanracer
It sounds like there maybe a network issue in the area, but you can check the BT/EE Network status by using the link below
BT/EE Network Checker
