Jwand
Newbie
Message 1 of 4
Phone won’t text
I get an error message each time I try texting today. Switched phone off and on with no change.
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: Phone won’t text
You could look for the many similar reports on this forum or go to the item at the bottom of this page.
Copykurt
Newbie
Message 3 of 4
I have the same issue, looks to be a problem with some mobile accounts, can’t even view usage data or remaining allowance. Hopefully it’ll get sorted soon. Wife really likes to text.
Distinguished Guru
Message 4 of 4
BT is having major IT issues, no texting, chat, and parts of BT.com is down
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
