Message 1 of 4
Pixel Watch LTE Esim - data sim only
HI All,
I'm looking for information on getting my Pixel Watch connected up via LTE.
I already have a deal with BT Broadband and 2 sims with 30 gb data a piece, sim only.
Is there an LTE bolt on, or a particular tarif i need to change to connect up the watch, even if that means going over to EE for the E Sim?
I've done some searching around can't find anything particularly on this.
Ideally, i would like to mirror my sim to watch and just the data allowance as i never use all 30gb. I realise this might not be doable, but that would be the best for me.
if anyone knows what to do, please get in touch.
thanks
3 REPLIES 3
Message 2 of 4
Re: Pixel Watch LTE Esim - data sim only
EE offer data only sim plans, and all plans are compatible with eSim.
If you have a standard sim plan with EE ie calls and texts you can also get a paired esim to use in smart watch which will share the data from your main sim too.
Anonymous
Not applicable
Message 3 of 4
BT don't support eSIM.
Message 4 of 4
Thanks, i've moved over to EE, hoping to get the "watch tariff" activated soon
