hmatull
Newbie
Message 1 of 3
Poor 4G Signal at Home address
I'm looking for assistance here please in terms of being bale to boost the 3G/4G signal at my home address which is consistently much worse than when being out and about. I only average 1 bar on my strength meter and consistently drop out of work Conference Calls which is extremely embarrasing (I work from home the vast majority of the time now which makes the situation worse!)
Is there a signal booster unit you can provide me with in such circumstances or alternatively can you please advise me how I can boost the 4G signal as currently the BT SIM Card isn't fit for purpose in my home/work environment?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Poor 4G Signal at Home address
@hmatull welcome to the community and thanks for posting, I'm sorry to see you're having problems with your mobile signal.  Is your handset compatible with our WiFi calling service as that may help?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 3 of 3
